Log4OM Portable will be maintaned ?
IW3RAB
Post by IW3RAB »
Last days I have full uninstall the Log4OM and try the "portable" version.
This operation permit the full copy of my data now in c:\log4om on exerternal support,
NOTE: the log file C:\Users\Sandro\AppData\Roaming\LogOM\log is still in user profile.
The conversion of configuration is not so trasparent, but can be realized.
Remember: print your configuration, some path can change.
PRO:
I can save my logbook
I can use my logbuk on other machines (PC)
No disinstall is needed
mydata is in my hands
no problems with UAC
PAY:
symply ?? install dot.net 4.0 and relative updatades not from Window Update
NOTE:
Windows Updades install only a reduced client version of "run time" of .NET
You must install the full version dotNetFx40_Full_x86_x64.exe in your language and do the relative updates via Microsoft updates
Please do not kill me
73 de IW3RAB Sandro
Sandro IW3RAB
VK7XX
Re: Log4OM Portable will be maintaned ?
Post by VK7XX »
I am having some problems with the portable version.
I have it on a USB memory stick... I put the stick in to computer A) and I created the database on the memory stick. I made many changes to the Layout (every column option was selected by default so I removed many). I have this all set up now, looking nice for me. I close the program down.
I take my memory stick to computer B). Computer B) is not connected to any radio, I just want to show the software to a friend... I start the program again..... but I get an error message that says Unable to generate a temporart class (result=1).
error CS0016: Could not write to output file 'c:\Documents and Settings\Fred\Local Settings\Temp\hz2j4lcm.dll' -- Access is denied.'
I click OK to close this message and get another 3 or so error messages (I did not write them down) and continue to click OK to close them..... eventually, Log4OM comes up on the screen, BUT it does not remember the name or location of my database, AND it has forgotten all of the Layout settings I made on computer A) Now here is the BAD part... IF I close the program down (computer B), and I plug my stick back in to computer A) once again, I have to make lots of changes to my Layout because it has forgotten all changes again.
I have repeated this swapping from machine A) to B) and back many times now and it is always the same.... it looses the Layout settings. one each machine, and does not remember the dadabase name and location on machine B).
However, the error message only appears once UNLESS I reboot machine B) and then, after reboot, I get the error one time.
This poses two questions for me....
1) why is a 'portable' version attempting to write anything to the hard drive of any machine ?? (machine 2 might be anywhere and belong to anyone and it should NOT be written to.) and
2) where are the Layout settings being saved to ?? not the memory stick in this case !
John
PS... I am happy to do any further testing of the portable version that you might want done.
IW3RAB wrote:Last days I have full uninstall the Log4OM and try the "portable" version.
PRO:
PAY:
NOTE:
73 de IW3RAB Sandro
Try this from page 133 of the user guide
Running Log4OM from a memory stick
1. In order to install Log4OM on a memory stick, it is necessary to copy the files from a LOG40M program that has been installed on a PC or download the ‘Portable’ version from the LOG4OM website.
2. Locate the C:\Program Files\IW3HMH\ folder and copy the Log4OM folder to the memory stick.
In the LogOMUI.exe.config file in the Log4OM folder located on the memory stick, add the * between the inverted commas "" in the line as below:-
<add key="ConfigurationPath" value="*" />
3. On the memory stick, create a folder called ‘Config’ inside the Log4OM folder. e.g
J:\Log4OM\Config
4. Locate the C:\Users\ USER NAME\AppData\Roaming\LogOM folder on the PC and copy the contents of the folder to the memory stick folder J:\Log4OM\Config
5. Create a shortcut in the memory stick root directory J:\ to the LogOMUI.exe which is located on the memory stick at J:\Log4OM
6. Plug the memory stick into a PC and double click on the shortcut to run Log4OM.
This works for me and nothing is written to the host computer!
G4NVB
Post by G4NVB »
In my Windows 7 system the files are located in:
C:\Program Files (x86)\IW3HMH\
Other than that, the above instructions worked ok for me.
73 de David G4NVB
Thanks I forgot that and I will add it to the user guide
EDIT: Done!
G4NVB
Post by G4NVB »
EDIT: Done!
I do like the friendly feedback from the Log4OM Team, much better than the *** team :D
73 de David G4NVB
IW3RAB
Post by IW3RAB »
G4NVB wrote:
EDIT: Done!
Thank for fast feedback
Please test the follow:
start Log4OM from the new device(memory stick F: for me), goto Help --> Show Log
Where the log file is located ?
In the log file I can read (date time are omitted)
Log4OMMainWindow: Program started
Log4OMMainWindow: Log4OM version: 1.11.5.0
Log4OMMainWindow: Log4OM folder set: F:\Log4OM\config\
Log4OMMainWindow: Log4OM backup folder set: C:\Users\Sandro\AppData\Roaming\LogOM\Backup\
Log4OMMainWindow: Log4OM hamlib folder set: C:\Users\Sandro\AppData\Roaming\LogOM\hamlib\
Log4OMMainWindow: Log4OM initialization start
BL.FileManagement: File Management begin load localization
BL.FileManagement: File Management localization loaded
Functions: loadTxtData file: F:\Log4OM\config\bandlist.txt
Functions: loadTxtData file: F:\Log4OM\config\rxbandlist.txt
Log4OMMainWindow: ******************** USER REQUESTED APPLICATION SHUTDOWN ********************
BL.HamlibManagement: DAEMON stop request issued
BL.Omnirig.OmniRigManagement: Stopping OmniRig
BL.Omnirig.OmniRigManagement: Runworker completed begin closing cat
BL.Omnirig.OmniRigManagement: OmniRig Stopped successfully
BL.BackupManagement: Backup start.
BL.BackupManagement: Backup folder is C:\Log4OM\Backup\
BL.BackupManagement: Log exported 712 records found
BL.BackupManagement: Creating backup file: C:\Log4OM\Backup\20130503121936_IW3RAB_Log4om.adi
BL.AdifManagement: Begin export to ADIF file: C:\Log4OM\Backup\20130503121936_IW3RAB_Log4om.adi
BL.AdifManagement: Export to ADIF file completed
BL.BackupManagement: Backup completed.
BL.FileManagement: CONFIG begin save
BL.FileManagement: CONFIG save completed
Log4OMMainWindow: BAND LIST load start
So I must also correct in configuration the backup location (found in Settings --> Settings1)
and Log4OM_log.txt location (NOT FOUND or not configurable) ,now in C:\Users\Sandro\AppData\Roaming\LogOM\log\ on windows 7
73 de IW3RAB Sandro
to the team that listens, understands, solves the problems...............
Sandro IW3RAB
Hi Sandro,
One of the other guys will have to test this, probably Daniele, because I am now away from home for a few days.
Sorry!
IW3RAB
Post by IW3RAB »
G4POP wrote:Hi Sandro,
Sorry!
no problems
there is only one subtlety in form load that will be corrected in the new version that I look forward.
Compliments for :
stability
speed
portabilty
to all the staff
73 de IW3RAB Sandro
NOTE: I have a lot of problems with JT65 and OmiRig. SOLVED by writing a bridge that simulate the swiss version of ??? to my poor 857 radio in C#.
Sandro IW3RAB
You are not forgotten Sandro, I have asked Daniele to check this out and respond to you
