I was just exploring the Stats and Awards utility having seen it mentioned in another thread. I was checking out the country status tab and decided that I would like to view the window with all columns visible.
The two colour keys stay on the very right of the window. Therefore, the wider the window the further away they are from where the colours are. Would it be better if they stayed on the left, next to the countries column where the colours are used?.
Also, I was wondering why the countries list has a collapsed view as it does not look as if anything can be done in that mode. Also, changing the actual view collapses the list, which then needs to be expanded again to use the new view.
Vy best 73,
Guy G4DWV/4X1LT
Country Status Tab
Country Status Tab
Re: Country Status Tab
Hi Guy,
automatic list expansion is related to the expected use of this function, that is checking for single countries the related informations.
For a complete overview of the statistics the other tab will provide you another glance on informations
