HI All
Happy New Year.
Please are we able to split the confirmed and worked in the cluster highlights. It gives me a misleading view in the cluster window. I want to be able to easily see unconfirmed DXCC bands and modes.
Worked and confirmed are 2 different things and they ideally should not be combined in a filter.
Martin - G6VMR
Cluster Highlight Options
- Cluster.JPG (35.64 KiB) Viewed 2675 times
Re: Cluster Highlight Options
Martin,G6VMR wrote:HI All
Happy New Year.
Martin - G6VMR
The Worked/Confirmed highlights are not combined, the highlight displayed depends on the selection made in the Cluster/Highlights tab as shown below
If "By Country" is selected then the highlight = "Worked" (The country is worked)
However if a "By QSL received", "By eQSL received, "By LOTW received or "By LOTW or QSL received" cluster filter is selected then the highlight = "Confirmed" (The country has been confirmed by receipt of whatever QSL method(s) has been selected in the highlight filter)
So in the examples shown below "Crete" is "Worked' by country - Not confirmed by Paper QSL - Not confirmed by eQSL but it has been confirmed by LOTW
Whereas Thailand although "Worked" does not have any QSL, eQSL or LOTW confirmation
Hope this clarifies it for you
- Capture.JPG (30.52 KiB) Viewed 2667 times
- Capture2.JPG (138.97 KiB) Viewed 2667 times
- Capture5.JPG (145.83 KiB) Viewed 2667 times
- Capture3.JPG (130.19 KiB) Viewed 2667 times
- Capture4.JPG (106.55 KiB) Viewed 2667 times
Thanks Terry. I was not totally aware of that feature, and will use it!
Doug - W7DRM
Doug - W7DRM
