Lost my info and config
Posted: 03 Jan 2015, 13:22
by EI2GLB
Hi All
My PC powered off last night after I shut down Log4OM, I turned the power off by accident,
Today when I go to start Log4OM I get the configuration screen as a new user, my setup is not in the drop down list,
If I enter my call and locator as a minimum and click save none of my qso's are in the log,
How can I restore the log ???
Trevor
EI2GLB
Re: Program has lost my info
Posted: 03 Jan 2015, 13:27
by K7PT
Happy New Year!
You should have a backup log located where you told Log4OM to store it. It will be a ADIF file. Find it and then import it.
Posted: 03 Jan 2015, 13:42
by EI2GLB
Happy new Year to you too,
I found my SQL lite database but I want to get the config file back too, would that be stored somewhere as well,
Trevor
Posted: 03 Jan 2015, 14:35
Trevor
The config backup is stored with the ADIF backup and will have the same date, see screen shot
The normal location for backups is C:\Users\YOUR USER NAME\AppData\Roaming\LogOM\Backup
Rename the file config.xml and copy it to your config folder letting it overwrite the new config that has been placed there
Posted: 03 Jan 2015, 18:02
by EI2GLB
Hi Terry
Thanks had to step a few days back to get it working but all seems ok again,
Wonder what went wrong??
Happy new year to you and thanks again for the help.
Trevor
Posted: 03 Jan 2015, 18:06
EI2GLB wrote:Hi Terry
where is my config folder ???
Trevor
Posted: 03 Jan 2015, 18:11
by EI2GLB
Thanks Terry I found it after I posted the first message you got in before I managed to edit it,
Trevor
Posted: 07 Jan 2015, 17:28
Trevor
HELP MENU -> OPEN CONFIG FOLDER...
just in case you have a portable version or hardly redirected your config folder tampering the application.config file :)
