eQSL verified indicator
DJ6JZ
Post by DJ6JZ »
In the QSO Information window there is a window showing the worked/verified status for the selected country. But received eQSLs are not recognized, the status remains W (worked). Would it be possible to let the display change to "E" for a received confirmation?
I realize that eQSLs are not regarded as coequal to paper QSLs by several OM, but for myself they are sufficient.
Another question: How can I create a small table that lists the number of worked/verified countries for the shortwave bands? Just the according total numbers per band, not a list of countries.
HNY, vy 73
Willi, DJ6JZ
http://www.radio-portal.org/index.html
The Radio Search Engine
http://www.sdr-portal.org/index.html
Mobile Version
https://www.youtube.com/watch?v=PTluWER ... e=youtu.be
sdr-portal on Youtube
ik2egl
Re: eQSL verified indicator
Post by ik2egl »
ciao Willi
for Eqsl I will let Terry or Daniele to answer.
For the list I can give you some suugestions.
a) you should open the qso archive window and do a rows selection using the Search criteria functionality: you will have all needed qsos
b) after that do an export in CSV format: you can also extract the column you need selecting the specific button and selecting the most suitable field separator
c) than you can import the CSV file in excel, and doing all dinamic filtering and ordering needed
hope it helps !
:D
73 de Don IK2EGL
DJ6JZ
Post by DJ6JZ »
Hi Don,
thanks for your quick reply. Well, I could export the worked / verified entries separately, then separate them again by band and let Excel count the number of lines. But that would not give accurate total numbers of countries.
I'll attach a screenshot of such a table which was created by the JT65 software of HB9HQX. I regard such a summary as very helpful - could such an option be added to Log4OM?
Willi, DJ6JZ
I will add something like that in V2. V1 if i have some spare time and if i can "recycle" code for V2 :)
Nice shot. Very clear and simple. Thanks
lele
