Two-way
G4DWV
Two-way
Post by G4DWV »
Is it possible for Log4OM to be receptive to two programs at the same time?
I would like to operate both JT65 and PSK31 at the same time on my rig (easily do-able), using both WSJT-X and FLDigi and have both logging into Log4OM. All works fb using one or the other.
Mni tnx,
Guy
Re: Two-way
As FLdigi uses XML/RPC to log directly to Log4om whereas JT alert logs directly into our database I cannot see any reason why this would not work, have you tried?
The only problem could be is both programs tried the send a QSO simultaneously
G4DWV
Re: Two-way
Post by G4DWV »
I'll give it a go!
Cheers
Guy
VK7XX
Re: Two-way
Post by VK7XX »
G4DWV - Guy wrote:I'll give it a go!
Cheers
Guy
Guy, please let the readers know the results of your test.
John
F4BPO
Re: Two-way
Post by F4BPO »
Hi John,
Have only tried one after the other but I would expect this to work at the same time if QSO not sent to L4OM at the same time.
They are using two differents way for adding contacts to the log...
Anyway I did not try so cannot confirm 100%
73 de F4BPO Greg
G4DWV
Re: Two-way
Post by G4DWV »
I just did a test with some dummy callsigns and it works fine - both calls from both progs logged correctly.
OT:- Does the v2 progress bar need an update, hi hi.
73 de Guy
