JCG - Japan Century Guns Award
Moderator: OE6CLD
OE6CLD
Post by OE6CLD »
Hi all,
Please find attached the award definition for the JCG - Japan Century Guns Award. If you're still using Log4OM < v1.18 manually copy the attached xml file (it should be named award_JCG.xml) into the <user>/AppData/Roaming/LogOM/awards folder (or in the confog/awards folder if you're using the portable version) and restart Log4OM.
Starting with version 1.18.0 Log4OM will update all awards automatically, there is no need to copy the awards file to a specific folder. We really would recommend to update to this or any newer version!
More information regarding the award can be found here: http://www.jarl.org/English/4_Library/A ... d_Main.htm
Claus, EI7JZ/OE6CLD
award_JCG.xml
JCG - Award
(412.03 KiB) Downloaded 562 times
Claus, OE6CLD/DJ0DX/EI7JZ
