The Net Control function no longer works for me with the new update ver.1.12.1 Its listed in the utilities menu but nothing happens when I click on it any advise on what is going on
Jess WB4PPW
Net Control
Re: Net Control
Terry, every thing works and function correctly except the Net Control function. When I click it, I just return to the main program. It worked fine with the previous ver.
Jess
Jess
Re: Net Control
I think that you should download again, uninstall the program and then re-install
Please ensure that you run the program as an administrator, there are many changes from the last version.
Please let me know what OS you are using and let me know how you get on after having done the above re-install
Re: Net Control
Thanks Terry, I already did the uninstall then reinstalled now everything works fine. Thanks for the quick response and helpful advise.
&3 Jess WB4PPW
&3 Jess WB4PPW
Re: Net Control
Hi Jess,
I am pleased that you have sorted it out, these sort of problems are usually either a bad download or a poor install.
Just for your information this release was the result of 11 Alpha releases, 3 release candidates and a pre release test of 1.12.1 last evening so when something does not work that we tested we usually find it is due to the above causes.
