Statistics and Awards Questions
ng2d
Post by ng2d »
I have questions regarding Statistics and Rewards.
What is the meaning of the red vs. blue colors in the Country Map and QSO maps?
Is there a way to limit the bands displayed in the Country QSO Status Grid?
Is there a way to change the column widths in the QSO Status Grid?
How can I save my settings in Statistics and Awards?
I don't see any information about any of these questions in the user manual.
Thanks,
Bill - NG2D
Re: Statistics and Awards Questions
ng2d wrote:What is the meaning of the red vs. blue colors in the Country Map and QSO maps?
Blue = confirmed
Red = Not Confirmed
Options/QSL and Labels - Uncheck the unwanted bands in the "Statistic filters"
Not at this time
Please explain what you need to do?
ng2d
Post by ng2d »
Thank you for your quick response.
I am interested in saving my last settings, like show only worked countries for example.
I would also recommend adding the information you posted in the user manual.
Thanks again - Bill
ng2d wrote:Thank you for your quick response.
Thanks again - Bill
Bill,
We don't have a save option for last settings and the windows are not Persistant upon closing, hopefully these problems will be overcome in version 2.0
HB9ETR
Post by HB9ETR »
Is there a way off completely deleting all selected award data and starting again?
Rob
HB9ETR / G0IFL
Win10 i5-11400 @ 2.60GHz
For which awards?
HB9ETR
Post by HB9ETR »
all....as if nothing was entered there in the first place.
Rob
HB9ETR / G0IFL
That would require resetting the QSL received status back to N- no for paper and LOTW - Are you certain that you want to do that???
Why do you need to do this, there may be other alternatives?
HB9BRJ
Post by HB9BRJ »
Had to do this myself because I had initially chosen an incorrect (generic) award.
This is how I did it:
Backup your database
QSO Manager > QSO Archive > check "Enable update" box
CTRL-A to select all QSO records > Field update > Field to update = QSO Awards > check "CLEAR FIELD" box > UPDATE.
Worked as expected. Maybe with some collateral damage but I did not notice any up to now.
73, Markus
sp8sn
Post by sp8sn »
Hallo. I have one question in this topic. How can I check in the statistics, how much grid squares I have worked on the band. For example, I want to know how many squares I have worked on a 4m band?
Regards, Robert SP8SN
73, Robert SP8SN
