FLDIGI and XML-RPC
FLDIGI and XML-RPC
I assume the proper method to integrate FLDIGI and LOG4OM is to start FLDIGI, enable XML-RPC and then run LOG4OM.
That seems to work fine. However FLDIGI doesn't automatically initialize the XML-RPC (or it doesnt seem to) so I have to do it each time.
Half the time I forget and have to start over.
Is there an easier way?
Re: FLDIGI and XML-RPC
You only need to initialise XML/RPC in FLdigi once, make sure you save the Fldigi config in the rig set up window and also the file drop Down!
From then on just start the programs and it works everytime
EXCELLENT !
I was missing the Configure>Save Config second part of the deal. I even added Log4OM to automatically start with FLDIGI and it seems to work perfect.
Thanks for help. Loving this program. A LOT
kd0zv
