I am migrating from DX4WIN to LOG4OM and I need to resolve some differences I see between DX4WIN and LOTW and LOG4OM. I would like to print some of the award matrix info so I can sit back and compare with side by side printouts. How do you print this info?
Harry
How to Print Award Statistic Info
Re: How to Print Award Statistic Info
At this point in time the only way is to export from the Award statistics window a .csv which you can then manipulate in a spreadsheet
- Untitled.jpg (205.33 KiB) Viewed 2916 times
Thanks for the info Terry, I have started to resolve the difference by printing LOTW matrix for each band and then using this against Log4OM matrix on screen. That method seems to work fine. I did notice one discrepancy that could be Log4OM problem. The country associated with prefix 9Q in Log4OM was being logged as Republic of the Congo whereas LOTW had it logged against Dem. Rep. of the Congo. I changed it to match what LOTW shows.
Harry
W0LS
Harry
W0LS
If you download from LOTW in Log4om using a start date before your earliest QSO then the QSL and credit status of every QSO in Log4om will be updated to match the LOTW records
Ok Terry...I did what you suggested (backed up the log first) and ended up with more issues than before....but...it forced me to read the manual! So I am learning....I may have more questions but for now I am trying to get educated...
Thanks,
Harry
W0LS
Thanks,
Harry
W0LS
