omnirig
Posted: 27 Apr 2015, 02:07
by AI4PF
Hello Terry: My previous problem with controlling the K3 with omnirig was, as I previously posted, solved. However, when I double left click on a spot in the super cluster, for example, the K3 immediately QSYs to the appropriate band and frequency, and for a brief second or two I can hear the station, but just as quickly the audio connection is gone to be replaced by nothing. Other times I don't even get a brief connection, just the K3 still in TX mode plus no audio. I don't know if it some setting in Log40m, the K3 misbehaving. What do you think?
Bill, Ai4PF
Re: omnirig
Posted: 27 Apr 2015, 04:33
Bill,
The double click on a spot function only sends the frequency and mode command to the radio, nothing else and there is not a log4om setting to cause the tx change
My thoughts are
1. a K3 Problem, maybe a menu setting?
2. Possible malware or virus infection on your computer
Have you tried a factory reset of the K3?
Re: omnirig
Posted: 28 Apr 2015, 18:56
by AI4PF
Terry: I contacted Elecraft support and laid out the problem for them. They opted for some additional research on their part and will get back to me.
There is an unrelated issue I am trying to resolve, but with no success. I have evidently setup a wrong sqlite path and it is interferring with the proper function of jt65 Alert. I don't want to be too aggressive in my efforts, because I want to avoid upsetting things altogether. Can you help me in the correct steps necessary to safely change the path in the program?
Bill, Ai4pf
Re: omnirig
Posted: 28 Apr 2015, 19:03
Bill,
Just change the path in JT65 Alert, you can see the correct path at the bottom right hand corner of the Log4om window
