I need a new ADIF import, how can I delete the old log so I can import fresh ?
73, Dick, W1KSZ
How Do I Delete My Entire Log
Re: How Do I Delete My Entire Log
The database file will be whatever name you gave it .sqlite, just delete the file and then create a new database from the log4om file menu
I don't find any file with a .sqlite extension.
I looked under the Program Files folder in the drive I placed
the program.
73, Dick, W1KSZ
the program.
73, Dick, W1KSZ
At the bottom right hand corner of the Log4om screen we display the path to the database file and its name!
I found it, deleted it and imported ADIF file again.
The phantom country (No-DXCC-Status, #999 Pfx ND) is still there.
From what I read, it's a known bug, guess I wait for the next update.
Tnx for the help,
73, Dick, W1KSZ
Tnx for the help,
73, Dick, W1KSZ
- VK7XX
- Old Man
Another way not so far mentioned, probably because its the long way round, but it does retain your current database name, is to open the QSO Manager window, change the search limit count to 0 so that ALL will be the search limit, click the search icon, click (bottom of window) 'Select All' then press your delete key.w1ksz wrote:I need a new ADIF import, how can I delete the old log so I can import fresh ?
73, Dick, W1KSZ
You can also do this in the red the post box icon, change the search limit count to 0 so that ALL will be the search limit, click any of the 3 tabs, click search, then on the bottom of the window, click 'Select All' then press your delete key.
Once you have deleted, then you can go to "File / Import ADIF" and bring in your 'new' log.
Like I said, long way round
John
VK7XX
I tried the Delete Key trick yesterday. It took forever and still didn't clear the log.
73, Dick, W1KSZ
73, Dick, W1KSZ
