startup with cluster connected?
G1YBB
Post by G1YBB »
I've managed to get the cluster working on my a test install now but was wondering if there was a setting to start up in that state?
To get it working I have run Log4OM, started WCF, connected TCP, then gone to utilities/cluster/connect.
Can I get it to start up doing those things?
I have found a tick box to open cluster on startup but that is a separate window, not what I wanted.
Re: startup with cluster connected?
That check box starts the cluster, connects and does what you require - Try it !
G1YBB
Post by G1YBB »
aha! yes that does just what I want.
Last night, when I couldn't get cluster or the callsign lookups to work, it operated differently, leaving a window up.
window closes automatically if you have a positive connection to the selected cluster server. Elsewere stays open
G1YBB
Post by G1YBB »
IW3HMH wrote:window closes automatically if you have a positive connection to the selected cluster server. Elsewere stays open
all working nicely now thanks.
