Imported log distance problems
Have tried the search function and found some "distance" problems but not mine :D
Befor i started using Log4Om i imported the ADIF of HRDlogbook. Today i take the distance field to my layout and i see that all qso (logged with Log4Om) shows the right distance. All imported qso showing "0" or farer distances from here to Mars or Neptune :D :D :D
Is there a funktion to edit this entry´s als a bulk like HRDlogbook did ???? I tried to change it manual via doubleklick on an entry an "Update" but that not works.
B.t.w. my locator is set in Log4Om and in the imported adif are the locators of the other stations too ..... Any suggestions :D :D
Re: Imported log distance problems
have found it at site 92 of the manual ....... all works fine :mrgreen: :mrgreen:
I am pleased that you found the answer let us know if you need assistance anytime
Terry, your manual is invaluable... it's really HUGE... :)
Daniele
Growing day by day Mate
Dont´t say "it works fine" without verifying ..... Have had club evening 2day and as i come back and started Log4Om no QSO´s was show´n in "Recent QSO" or "QSO Archive" or somethink liker this. The Software shows me my QSO Number "14907" but no entries ..... No Call, No Time and if i said "refreh" he makes "Busy" for a tenth of a second and fields are empty again. How bring i back my log to display the contacts ???
I checked the "new updated" manual but i don´t find out how to restore a database .... :(
This has to be something simple like a search parameter set but returning a zero search result, but to answere your question..
1. File/open database then locate your SQLite file something like DF5WW.sqlite or whatever you called your database - Click open and it should all be back.
Or
2. If option 1 above does not work select File/New database - select a location and provide a name then click save -
This should then open with an empty database.
Now File/Import ADIF and navigate to where you saved your backups, probably the Log4om/Archive folder and select the latest backup.
Click import and when imported close the import window.
Your QSO's should display in the Recent QSO window.
Puuuhhhh .... all be back .... (Your #1 don´t works) ... The stored backup was in "User/DF5WW/APPDATA/ROAMING/Log4OM" (Win7 64 Bit) so i use your (#2) ... works ..... But what did i do wrong. I tried to Update my distances via bulk editor. Locators in the imported ADIF and mine is stored in the settings. How can i update the distances when showing "0" or Kms like "63008756"??? B.t.w. have my last HRDlogbook ADIF here if you won´t to check the differences. Only 1.7 MB as a ZIP-File :mrgreen: :mrgreen:
Please email it to me Jurgen
Will do :D :D
Looks like that the ZIP is on the way to your email found at qrz.com.
