Just a simple question, I am want to use a cluster that is not on the list, how do you add another cluster to the program?
Thank you
Roger G4OCO
Adding another cluster
Re: Adding another cluster
First tab in options, click expert mode and edit the cluster text file
Terry
Thank you for your answer, very fast response.
Roger
Roger
I am in need of further help, still trying to log into another cluster.
Trying to edit the cluster configuration file has resulted in the file being corrupted and log4om is unable to find it, so I have several questions:
Can I recreate another login file, to have callsign and password contained within the script, but there needs to be a pause between sending the login callsign and a password.
What type of file extension is it and lastly where does the file reside, in other words which directory?
By the way I am a member of the Chiltern DX club and trying to use the clubs cluster
Thank you
Roger G4OCO
Thank you
Roger G4OCO
Roger,
Email me with the cluster details and your login details and I will edit the files and email them back to you
I am also a Chiltern DX Club member
Out of interest, I have been using the new beta 3 version of VE7CC cluster client software. In ver 3 of VE7CC you can connect up to 5 cluster nodes simultaneously. I connect to both CDXC and GB7DXS (and occassionally my CW Skimmer) simultaneously. This way I can see the CDXC CUG spots as well as all the RBN spots on DXS.
Peter G3ZSS
Peter G3ZSS
73 Peter G3ZSS
Peter
That is interesting about the VE7CC cluster software and how you use it, I will see how things pan out with the fix Terry is kindly undertaking for me.
I can see the usefulness of watching several clusters, requires further thought.
73 and thank you for planting a seed in my mind
Roger G4OCO
Roger G4OCO
We resolved Rogers problem today by adding a delay feature in the cluster script to allow for servers that take time to data check
Terry
Sorry to be a pain, can you please send the cluster configuration file again, as I have changed computer recently and can not find the original email you sent.
Thank you
Roger G4OCO
Thank you
Roger G4OCO
