Power levels below 1 watt
k3dcw
Post by k3dcw »
Are there any plans to include support display and saving of power levels below 1 watt, such as 0.1w or 0.005 watts, etc?
For some people who really enjoy using QRPP, and for those that use modes like JT65 and/or JT9 which support such low power levels, it would be useful to support saving this info.
Thanks in advance and 73,
Dave
K3DCW
K3DCW
Elecraft K3
Re: Power levels below 1 watt
k3dcw wrote:Are there any plans to include support display and saving of power levels below 1 watt, such as 0.1w or 0.005 watts, etc?
Dave
K3DCW
Hi Dave,
Data received from JT65 and JT9 is recorded correctly already :D
However we need to add QRP power level logging in Log4OM
I need to check the field in the database.
If i remember well is an INTEGER. In that case i can change it, but requires a release and some changes in the code and database structure.
Daniele
PB4FUN
Post by PB4FUN »
Tried out the program yesterday. As QRP-operator this is something that would not let me want to use this program (so very important)
I understand it is not very easy to change an int to float everywhere, but maybe you could add a field to calculate the real power.
If you add a combobox with nano-, micro-, milli-, watt, kilo- and megawatt and take as values for those -9, -6, -3, 0, 3, 6 (default 0) the user can still use an int for the Trx/Rx Power field, e.g. 20, but in addition to it with a -3 it will be 20 milliWatt and you can use a calculated field in the grid for sorting.
Maybe the overview of worked/confirmed etc could also be expanded with worked under x W or so.
The sub one watt issue has I believe now been resolved for the next release.
I don't understand your comment about worked/confirmed please explain in mor detail
next release will have a "new" field able to store power with 3 decimals (milliwatt).
This field will be an additional, non adif compliant, value that will be set with the "standard" TX_POWER field.
RX_POWER will be duplicated too.
Do we realistically should provide ability to store values lesser than one milliwatt?
PB4FUN
Post by PB4FUN »
As I do have QSO's in my log with 20 mW, yes. Otherwise they will be listed as 0 W.
With the increasing popularity of modes like JT65A people will want to use lower power also.
The worked/confirmed part I talked about is like the normal screen with DXCC worked/confirmed Ph/CW/Digi (or others like WAS/IOTA)
But with the possibility to show only those worked under e.g. 5W
In other words if I would have had worked OZ with 100 W during a contest or so I would like to know if I have worked OZ also QRP
(Did you know there is a QRP-DXCC award as well ?)
PB4FUN wrote:As I do have QSO's in my log with 20 mW, yes. Otherwise they will be listed as 0 W.
The question was do we need to go lower than 1mw
We have stated already that the next release will allow sub 1 watt entries like 20mw but do we need to go lower than 1 mw?
PB4FUN wrote:The worked/confirmed part I talked about is like the normal screen with DXCC worked/confirmed Ph/CW/Digi (or others like WAS/IOTA)
But with the possibility to show only those worked under e.g. 5W In other words if I would have had worked OZ with 100 W during a contest or so I would like to know if I have worked OZ also QRP
Now I understand and yes thats a good idea so I will add it to our Mantis list, thank you for the input.
Oh really! :o
Yes we do know that there is a QRP-DXCC award and also many other such QRP awards, FYI I also work QRP with several of my home-brew CW only QRP radios and even with them while HF Packing despite my being 74 years of age :D
Meanwhile you could use the search parameters in the QSO Archive manager to search for all QSO's where TX Power is less than 5 watts (TXPwr<5) this would provide a filtered list which could then be filtered further for QSL status or whatever other parameters you wish to apply.
Admittedly this will not display and awards grid :cry: but it might help you while you wait for such filtering in the awards statistics :D
