Just got back on 6m, quite active. I am trying to log the contacts using Log 4. I thought that I could enter the freq and band manually and click on the lock icon. I get a message that freq and band do not match. If I continue the band is logged correctly but the freq is that of my HF rig. I tried turning off the HF rig but that did not help.
Went through the USER GUIDE, but did not find the answer.
Any ideas????
Andy, W3LI
logging calls on 6M using Log4om
- VK7XX
- Old Man
Re: logging calls on 6M using Log4om
when you type in the frequency, are you also entering a decimal point ??? If you are, try putting in the frequency without a decimal point.
John
VK7XX
John
VK7XX
You should also select "Suspend CAT control" in the setings menu
Hello John,VK7XX and Terry, G4POP. Thank you both for the information on logging 6m calls. Both suggestions worked together and fine.
Tnx agn, Andy W3LI
Tnx agn, Andy W3LI
