Cluster info.
W3LI
Cluster info.
Post by W3LI »
I am using k3ww.gofrc.org:7300 cluster to feed Log4om. It has worked perfect for over a year. Now, Log 4 stops picking up the data and I'm missing good DX. I find that I have to disconnect from the cluster and then reconnect in order for Log4 to become alive again.
I am watching the cluster on another computer and it is very active.
Super Cluster works very well.
Any ideas?
Andy, W3LI
Re: Cluster info.
In the cluster connect screen make sure you have the stay alive "Heartbeat" box checked
W3LI
Re: Cluster info.
Post by W3LI »
Hello Terry,
Yep, the little box was unclicked???? Must have done it during the upgrade for some reason.
This brings up a question that I have been meaning to ask. On the settings pages and others there is a floppy disk labeled save settings.
Where are these settings saved and how does one retrieve the saved settings????
Tnx Agn
Andy, W3LI
Re: Cluster info.
They are saved to a file called 'Config' which is in your roaming/LogOM folder
When auto backups are saved there is also a backup saved of the config file incase a restore is required
The saved settings are retrieved when you restart the program automatically
W3LI
Re: Cluster info.
Post by W3LI »
RRR, TNX
Andy
