Error on Install
Error on Install
Tried to install the new update and this is the error messahe:
- VK7XX
- Old Man
Re: Error on Install
might seem like a silly question, but did you run the update as 'administrator' ?? The last line of that error message seems to indicate that higher privileges might be required. (I may be wrong tho..)
John
John
This is an issue that happens when you run Installer without high privileges.
Program is correctly installed but the setup cannot run it as requested.
I'm working on that issue, but seems to be more complicated than expected.
If you're using communicator and external hardware is recommended to run Log4OM as admin.
