ICOM Cat Support
ICOM Cat Support
I have two ICOM rigs. One is a IC-746 non pro. The other is a IC-707. The ic-746 works fine with omni-rig. IC-707 will not work with hamlib or omnirig. there is no definition for the ic-707 in omni-rig. It was suggested i use a definition for a yaesu rig for the icom ic-707. None of the yaesu definitions work. Both of the radio work fine under Ham radio Deluxe. Please help I use this rig a lot and would love cat control with it! Thanks!!!
Re: ICOM Cat Support
It is working with the Ic-725a rig descriptor. Thank You!!!
