Hi
for which it needs:
http://rtc-dl.de/log4om/award_WRTCM.xml
vy 73 Ingo
Award WRTCM Worked RTC Members
Moderator: OE6CLD
Re: Award WRTCM Worked RTC Members
Thank you
I will ask our Award Manager to check the file and the add to the official set
H Ingo,
Thanks for your work. I will give it a try. Right at the moment Log4OM is not ready to handle club memberships (like DIG, RTC, HSC, ...). The file you provided is a workaround, but not really a solution I like. E.g. if you work a German station and select the WRTCM award, it shows a lot of other German callsigns. You next have to verify if the callsign you worked is in the list - if yes you can add the award entry, otherwise you have to cancel.
It would be much better the other way around. Log4OM checks an internal file/database for memberships and if you work a call, all valid memberships will be shown. But that's a functionality we don't have yet.
Claus, EI7JZ/OE6CLD
Claus, EI7JZ/OE6CLD
Claus, OE6CLD/DJ0DX/EI7JZ
Yes, that is an open option also in award structure, that is able to handle callsigns but his management is not ready yet.
