If I click on the Time column in the Cluster display (F9), then the list orders by time. Unfortunately, if the list spans 2400Z, the list is wrong, because the column ignores the date. It's not a big deal because I rarely choose the sort the list at all.
The only way I have found to correct this is to restart Log4OM. Is there any other way to get the list to sort as if you'd just started Log4OM?
73, Gareth - M5KVK
Resetting display order on cluster screen
Gareth, M5KVK
Gareth, M5KVK
Re: Resetting display order on cluster screen
just select and then deselect a filter like Phone or CW the window will refresh to the previous state
Any of the filter being selected and then deselected will force a refresh
The same problem seems to occur with the recent QSO window. Clicking on any column sorts, but is sticky. I can't get it to unsort.
Gareth, M5KVK
Gareth, M5KVK
Ignore that, I found the refresh button
Gareth, M5KVK
Gareth, M5KVK
