F11
W3LI
F11
Post by W3LI »
Still learning some of the functions that are available within Log4.
When I click on F11 I get a blank page except for a blank tool bar?????? with a red check box and a green check box on the right side.
I click on a DX spot then lookup and that seems to be as the user manual states.
What else is suppose to happen using F11.
Not much in the user guide.
Andy, W3LI
K7PT
Re: F11
Post by K7PT »
F11 is for three purposes.
1) when clicking on the lookup button (right side below LOTW User), it will do a QRZ lookup and display in F11.
2) In the Utilities drop-down, clicking on the Log4OM SCL Contents displays a web page with the status of the SCL.
3) You can also enter a URL and click on the green button to display the URL contents.
W3LI
Re: F11
Post by W3LI »
Thanks Chuck,
Item #1 works fine although I use HamQth instead of QRZ.
Will try 2 & 3 next.
Andy
