eQSL card images: impact on dB
hb9cat
Post by hb9cat »
I find the possibily to "attach" an eQSL image to every confirmed QSO very interesting and thank you for this addition.
Yet: I'm often accessing the Log4OM Database via Log4OM/MySQL from a remote location, it's taking quite some time to get in sync; the question is: will every card image get uploaded as well as Log4OM initially loads the Database ?
If yes, it would probably drain performance significantly
Marco HB9CAT
Re: eQSL card images: impact on dB
Hi Marco,
no, the image is not saved in the database, due to performance and size issues.
Images are saved in the file system, configuration folder is the default (into a subfolder), if not differently set in the configuration
