eQSL card images: impact on dB
Posted: 17 Sep 2015, 14:49
by hb9cat
I find the possibily to "attach" an eQSL image to every confirmed QSO very interesting and thank you for this addition.
Yet: I'm often accessing the Log4OM Database via Log4OM/MySQL from a remote location, it's taking quite some time to get in sync; the question is: will every card image get uploaded as well as Log4OM initially loads the Database ?
If yes, it would probably drain performance significantly
Marco HB9CAT
Re: eQSL card images: impact on dB
Posted: 20 Sep 2015, 19:36
Hi Marco,
no, the image is not saved in the database, due to performance and size issues.
Images are saved in the file system, configuration folder is the default (into a subfolder), if not differently set in the configuration
