I would like to present an idea concerning Cluster filters.
I would like to have all calls on HF ( no continental filter), but, at same time, I would like to have calls to 6 meters band that the spotter is only from Europe (or even better from user's country)
Reason sometimes is useless to have spots on 6 meter from other continents . (both at same time)
Do you found it interesting?
73 Manuel Fernando - CT1BXX
Cluster with "special filtering"
73 Manuel Fernando CT1BXX
Re: Cluster with "special filtering"
Hi Manuel,CT1BXX wrote:Hi,
You can already do this by setting the F9 cluster window to show all HF and the F2 cluster to show spots only from the EU for a specific band
- one band.jpg (112.12 KiB) Viewed 2919 times
- HF.jpg (374.21 KiB) Viewed 2919 times
