FlexRadio just released a new version of SmartSDR and Log4OM no longer seems to have CAT control with the radio. Would it be possible to check and see if something may have been broken with the new release.
Thanks, Ron
K2RAS
SmartSDR 1.5 (FlexRadio)
Re: SmartSDR 1.5 (FlexRadio)
Without having a Flex 6000 series radio with the latest version of smartSDR it's impossible for us to see what might have changed in SmartSDR
We have not changed anything in Log4om
I found the problem,running the SmartSDR 1.4.3 installer did not install VSP. We needed to browse to c:\Program Files\Flex Radio Systems\SmartSDR v1.4.3\64 bit drivers\VSP and manually install it. A couple of reboots and the system came up.
Sorry for the inconvenience, we love Log4OM!!
Ron
Ron
Ron
Everything worked smootly for me with the 1.5 upgrade to my 6700. My only issue now is if I click on a RTTY cluster spot, then the rig switches mode to DIGU and not RTTY. But I think this is a limitation of Omnirig and something we will have to live with.
73 Peter G3ZSS
73 Peter G3ZSS
73 Peter G3ZSS
I just switched to Log4om with Flex6300 using Omnirig for rig control. Works great and I'm liking this program the more I used it.
...Gary, KE8O
...Gary, KE8O
I've been using LOG4OM for the past 4 updates and it's worked flawlessly with my 6500. Never even a minor glitch with each update.
So much more reliable than HRD.
