By way of a suggestion related to the thread pertaining profiles and switching profiles, I propose that it would be helpful to add an option in the CAT & Cluster tab to preselect and switch to rig 2 under Omnirig when the program restarts under the new active profile.
73 de David KT5V
Add option to select rig 2 in profile
Re: Add option to select rig 2 in profile
I'll check if this is "selectable" by code...
