Hi
This would be great if we could link our cluster spots to the vocap predictions similar to this sites implementation.
http://www.dxsummit.fi
Also our grey line map looks a little dated. Can this link into google maps or similar with a zoom able feature. Call selected also only shows one route which is half the time incorrect for the propagation. E51MKW would show you long path if you select the call in the cluster. Through the dark.
Now if we could have a great circle map that would be even better.
I support and use log40m 100% just want it to be even better than the rest.
Martin - G6VMR
Predictions and Grey Line
Re: Predictions and Grey Line
A better map is on list (with lower priority).
Opening external links is relatively easy but requires a bit of analysis.
Unfortunately working with maps is not something i'm able to do with ease
