Incorrect Clublog Upload Status
Posted: 16 Oct 2015, 08:46
by G4AON
I had Clublog set to update on QSO entry, however I wasn't "on line" and finished working 3 stations in a net.
I exited the net control by sliding the calls to the right hand box and they were entered on the log and show under recent QSO, the Clublog Upload status shows "Y", yet they are not uploaded and cannot be uploaded as I was not connected to the net at the time.
This might be a config issue rather than a bug, but clearly showing incorrect status information isn't right.
73 Dave
Re: Incorrect Clublog Upload Status
Posted: 16 Oct 2015, 09:21
If you realise that the upload has failed because you have not had an internet connection just right click on the QSO and select 'Upload/Update to Clublog <Call sign>' as shown below
- Untitled.jpg (65.39 KiB) Viewed 7063 times
Did you not see a 'Not connected' warning window?
Posted: 16 Oct 2015, 10:51
by G4AON
The fundamental flaw is the "Y" in the Clublog Upload status column on the recent QSO display. Yes, I can manually check that my internet connection hasn't dropped and that Clublog shows my recent QSOs, but that isn't convenient most times and the status report of Log4OM should be the primary means of identifying if the upload was a success, or not.
73 Dave
Posted: 16 Oct 2015, 13:25
I'll check the code. Thanks for reporting
Posted: 16 Oct 2015, 13:32
IW3HMH wrote:I'll check the code. Thanks for reporting
Depends if we get an answer back confirmation from Clublog Lele
Posted: 16 Oct 2015, 14:45
by G4AON
G4POP wrote:Depends if we get an answer back confirmation from Clublog Lele
As a first step, not being able to connect to the Clublog site could flag up a message perhaps? Or at least avoid showing the status as "Y".
Posted: 19 Oct 2015, 10:43
G4POP wrote:IW3HMH wrote:I'll check the code. Thanks for reporting
Yes, this is what i'm checking
