LOG CONTROL
G0VWP
LOG CONTROL
Post by G0VWP »
I have been using the log control to fill out a net this morning all was ok but now trying to do another log for a different net.
One was for the RSARS net which run ok.
The other was for a VK/ZL net entered all in the top and pressed new nothing happened and cannot put any call's in at all.
Terry
G0VWP
Re: LOG CONTROL
Terry,
I think that the name that you gave it may be the issue, I tried VK/ZL Net and it would not work, whereas VK & ZL Net did work so its probably the slash (/) causing the problem
Try entering Oceania Net or VK & ZL Net
Now click 'New Net'
Then click 'Open Net'
G0VWP
Re: LOG CONTROL
Post by G0VWP »
Thank you that was the problem / ok thank's again love the log4om I was using Logger32 but like this better
ok.
Terry
G0VWP
Re: LOG CONTROL
I'll check the encoding, thanks for reporting
