1st time trying to config Green Heron RT 21 control box. The manual is not making sense to me. Do I need other programs to make this work like I needed for rig control? What set up tab should I be working with?
K0com
Config instruction - Green Heron rt21
Re: Config instruction - Green Heron rt21
I have not setup Green Heron before, but it is likely you need PSTRotor control software as interfacing software between Log4OM and the Green Heron control box. See page 162 of the Log4OM manual for specifics.
Here is a link to PSTRotor. Note, it does work with Green Heron RT-21 and RT-20 controllers. http://www.qsl.net/yo3dmu/index_Page346.htm
Let us know how that works out or if you have other questions.
Doug - W7DRM
Doug - W7DRM
