I see that the Comment field has a drop-down list [QSO Info (F1)]
Can several (standard) comments be saved somewhere, or is this drop-down used for some other purpose?
73, Martin, G4DUL
Comment entry in QSO field
Re: Comment entry in QSO field
Precompiled comments are retrieved from cluster, in case you find references or other useful informations in previous spot informations.
You can fill a new comment or retrieve/edit a previous comment, but the comment field is only one, the one you see.
