Page 1 of 2
Email alerts
Posted: 08 Nov 2015, 10:08
by N8MSA
Hi -
I can't get email alerts to work; alerts are shown in the Communicator Activity Log as being sent to Communicator (tested via Cluster Spot Simulation), but all of the configurations and services that I have tested result in an "Error sending email" message. I have used Telnet to insure that I can connect to the servers and their required ports and I'm reasonably sure that entering the proper authentication information, so I'm at a bit of a loss.
Any ideas?
Thanks,
Mike - N8MSA
Re: Email alerts
Posted: 10 Nov 2015, 11:42
Communicator is running? Did you see those email in communicator log file?
The workflow is:
log4om detects the alert -> sends message to communicator -> communicator receive the message -> communicator sends the mail
first 2 steps are logged in Log4OM (enable trace mode from help menu to have more details), last 2 are in the communicator log.
Can you find where this chain broke?
You did the right thing with cluster simulation :)
Re: Email alerts
Posted: 17 Nov 2015, 12:52
by N8MSA
Hi -
Sorry for the delayed response, just returned from business travel...
- Communicator is running and connected.
- I can see the request from the Cluster app to communicator
- Communicator indicates that it is sending the email; there are three log trace lines up to the point that...
- A trace line appears indicating an "Error sending email", along with a long text string.
So...it seems to be failing at the actual email server connect-and-send step.
Thanks,
Mike - N8MSA
Re: Email alerts
Posted: 17 Nov 2015, 15:28
Please reproduce the issue and then fill a "support request" package from help menu.
This will produce a zip file that contains informations i need.
send them to iw3hmh (at) log4om.com with a brief note about this ticket, so i can find the issue
Re: Email alerts
Posted: 17 Nov 2015, 17:29
by N8MSA
Email sent, and thanks...
Mike - N8MSA
Re: Email alerts
Posted: 04 Dec 2015, 12:57
by N8MSA
Hi Daniele -
Any thoughts on this issue?
Thanks,
Mike - N8MSA
Re: Email alerts
Posted: 04 Dec 2015, 22:11
Yes, there is a "strange" issue on your main log file, that i'm investigating.
Are you running Log4OM as administrator?
Can you kindly reproduce the issue once again and send me the file named
Log4OMCommunicator_log_<yyymmdd> that resides in your Log4OM log folder? (help menu -> open configuration folder -> open the LOG folder inside the configuration folder. Here you can find the file)
thanks
Re: Email alerts
Posted: 05 Dec 2015, 16:56
by N8MSA
Hi -
Thanks for the help; new report sent.
73 de Mike - N8MSA
Re: Email alerts
Posted: 14 Dec 2015, 12:44
by N8MSA
Lele -
Any additional insights?
Thanks,
Mike - N8MSA
Re: Email alerts
Posted: 15 Dec 2015, 16:37
Hi Mike, not yet, i was busy with 1.24
I should reserve some time for watching some support requests that holds on my desktop
