Statistics and Awards, WAS issue
N9LQ
Post by N9LQ »
Hi, not sure if this is an issue or operator error. When going into Statistics and Awards, WAS, Mixed, the grid shows a green box for Verified, and a dark box for Worked. When I click on the Worked box, I can't always see the relevant QSO. It appears that if the State is not all in upper case, it won't appear. If I manually edit the state to be all upper case, then it will appear. I can easily do a mass update of all the states to upper case, but any new QSO's default to first letter capitalized, second letter lower case. Am I missing something here?
73, Joel N5FIW
p.s. First time poster, and I love this program. Thanks for all your amazing development work and sharing it with us.
73, Joel N9LQ
NN7D
Re: Statistics and Awards, WAS issue
Post by NN7D »
Hi Joel,
I think you have discovered a flaw. You are correct, unless the state is Cap for both characters, the WAS grid does not pick it up. In my case, I am using HamQTH as external source and when logging a new QSO, or doing a QSO Archive Update Info, it fills the State field with Upper/lower case, as in Tx. Maybe users of QRZ suffer a different fate?
Daniele, can the WAS grid be changed to recognize mixed case, or modify the update of state field to force all caps?
Thanks for reporting Joel!
Doug - W7DRM
N9LQ
Post by N9LQ »
Doug,
Thanks for the quick reply. My default external source is QRZ.com, and my default web external source is HamQTH. My QSO's appear to default to mixed case also.
73, Joel N5FIW
73, Joel N9LQ
i'll investigate. Thanks for reporting
Found and fixed in next release. Thanks for reporting
NN7D
Post by NN7D »
Thanks Daniele!
Doug - W7DRM
N9LQ
Post by N9LQ »
Wow! Fantastic response. Thank you again for all your work on this!
73, Joel N5FIW
73, Joel N9LQ
