Has anybody noticed that the download date on eQSL doesn't remember the last date but uses the current date instead?
LOTW QSL download remembers....but eQSL does not.
Mike W9MDB
eQSL download date
Re: eQSL download date
This is a know issue that has ben reported elsewhere on the forumw9mdb wrote:Has anybody noticed that the download date on eQSL doesn't remember the last date but uses the current date instead?
Mike W9MDB
Needs to be tested in alpha3 under compilation....
If you need somebody to test I'll volunteer.
As of 1.24.0.0 eQSL date still does not remember last download. Always uses current date,
Mike W9MDB
Mike W9MDB
This date is a nightmare...
it took less time to rewrite the Whole EQSL code than find why this date will not be saved correctly
Probably will be one of those "duh" moments when you find it.
Mike W9MDB
Mike W9MDB
ahahha yes, i've couple of those "Duh" moments lately...
after the "Duh" i'm usually bouncing head on walls for 2-3 minutes...
