I'm fairly new to LOG4OM and had not been using LOTW for a while. LOG4OM was recently installed on a new PC (Win 7 PRO). I have attempted to upload some QSO's and everything appears to go fine including the message "success; log signed and uploaded and accepted without incident" followed by a couple success in "logging" messages and then "Operation completed". The LOG4OM display of QSO's does show the data was "R"eceived by the remote site on today's date.
One problem - the new entries do not show up on LOTW. (Waited a whole day just to make sure the entries weren't in a queue someplace.) Older entries are there. Executing a "download" request works just fine in updating some older QSL verifications. This would appear the LOTW login credentials are fine.
Thoughts --
John WA0DGW
LOTW upload issue
Re: LOTW upload issue
Hi John,
When you upload and the Upload LOTW window displays the activity, do you see "Attempting to upload X QSO's" text, with X being something greater than zero! And do you see "Log uploaded successfully with result "File queued for processing...""?
If you are still having issues, go to Help, turn on Debug Mode/Trace, then do another upload attempt to LotW, then in Help/Send Bug report - follow directions, then send zip file which will be saved during the bug report process to svtdoug (at) gmail (dot) c0m.
Do not post that zip file on the forum as it may contain confidential information.
Doug - W7DRM
Doug - W7DRM
Just to close out this issue, it was found that the path specified in Log4OM Setup/External Logs tab, LOTW Settings Executable path was incorrect. Now that the correct path to TQSL has been entered, John can now upload to LotW.
Doug - W7DRM
Doug - W7DRM
