I'm using the software from few months now and he do the job very well. I've just an issue with the dowloading from LOTW. The upload works very well and the script is complete but when i would like dowload the confirmed QSO with the same ID, there is not script and i receive directly the operation completed Pop up without any result.
I search some info in the forum and on the web but i don't find informations.
Thanks for your answer,
Laurent
ON4AR
Download from LOTW
Re: Download from LOTW
Check your date range (starting date) of the download.
Hello Chuck,
Thanks for quick answering!
I've tried without date range or with a date range before my first QSO with this program with no result. I've also check the user ID and i don't use a password.
Laurent - ON4AR
Laurent - ON4AR
Laurent,
The password is not the same as the upload as that is for the TQSL program. It's the one you use to log into the LOTW website.
Chuck,
YES ! It works properly now!
Many thanks for your help,
Laurent - ON4AR
Laurent - ON4AR
