Cat control
F1VEV
Cat control
Post by F1VEV »
new set up finding my way round I 0ahve omni rig talking to my IC 735 however
If click a spot mode changes on 735 not band ?
If I move dial on 735 the CAT/Log follows.
If change mode on 735 mode does not change
If I enter a qso it will not add it until I have manually enter the mode
something must be amiss in my cat set up tried also with WSJT and no go either
thank you
Icom 7300- Dipoles
BY-1 Bencher - KT-1 keys
PCIntel i3 3.3GHZ - 16GB Ram - 1To external backup - QL700
PC: Win 10 Pro X64 - MS Office. Avast. NTP 4.2.8
Log4OM - N1MM - MTTY - WSJT-X 1.6.0 - JTAlert 2.8.4
Memberships: REF - ARRL.
Re: Cat control
It may be that your radio does not support all commands due to its age
However make certain that you have the latest version of Omnirig installed, I think its V 1.6 and also the latest rig files
F1VEV
Re: Cat control
Post by F1VEV »
Thanks Terry
I do have the latest omnirig 1.16 and associated files and 1.16 does support the 735 and yes its as old as my licence ...... :
I will hunt around for more info I cannot be the only one using a IC 735 WSJT-X and JT-Alert which accounts for 95% of my work.
I was hoping to get away from HRD 73 Jacques
Icom 7300- Dipoles
Re: Cat control
F1VEV wrote:Thanks Terry
Try changing the Poll Interval in Omnirig to 100ms and report what happens
F1VEV
Re: Cat control
Post by F1VEV »
Hi Terry
changing polling made no difference fro the moment using HRD radio control only and JT65 to Log4OM works fine
Icom 7300- Dipoles
