I went through the procedure to upload to eQSL and get this message
" Error NO MATCH ON EQSL_USER/EQSL_PSWD"
I checked the password in eQSL and inside the Log4OM external logs section to make sure they are the same.
I see that "Automatic upload on new QSO" is ticked in the eQSL section of Log4OM, but it does not appear that any have been uploaded since June which was when I had my new call.
The call and password are the same in both areas.
I did an upload to LOTW today and that worked.
David
VK5PL
eQSL Upload Problem
Re: eQSL Upload Problem
Hi David,
for eQSL uploads you need your Call, the password and the QTH Nickname ...... You can find the QTH Nickname on eQSL.cc in your "Accounts" ..... If you dont entered a nickname upload will be not work ....
Thanks Juergen, that fixed it. Apart from having the old QTH nickname in there, I realised I did not have the 5 in my call either, VKPL was never going to work. At a quick glance it looked OK.
Thanks for your help, the QSOs uploaded OK.
David
VK5PL
David
VK5PL
David
VK5PL
David
VK5PL
