Hi all,
I use this usb cw keyer and it runs very well with n1mm and also with log4om
http://www.g4zlp.co.uk/unified/DigiMaster_CW.htm
the only problem is that I've following message on F1
"CQ CQ CQ DE * * * CQ CQ CQ DE * * * PSE K"
and keyer play alsways "CUL PSE KE IK0PUL..." (I see in the echo text field)
same story with other messages... it seems log4om sends wrong chars to the keyer...
what's wrong ?
73 de ik0pul
winkeyer problem
Re: winkeyer problem
Please reproduce the issue, then go in the HELP menu and prepare a SUPPORT REQUEST.
This will produce a ZIP file. Send the file to iw3hmh (at) log4om (dot) com
Bug report sent. Any good solurion?
I have it.
I've looked into, but unfortunately you enabled the debug mode too late.
Debug mode enables a couple of log writings in the program log, but this works only AFTER you enable the trace mode.
If you enable trace and create support package, there isn't any trace of the error in the log.
You should ENABLE trace mode, then reproduce the issue.
In the case trace mode doesn't give us any evidence of the error, i'm usually produce a special debug version with more trace logs in the reported function.
At a first glance, anyway, it seems your winkeyer is sending something "autonomous", because i didn't have seen the string you reported in the list of commands... and this is strange.
Is there any other software running at the same time, that can intercept the Fxxx command?
Did you try disconnecting the Digimaster from the USB port, just in case there was something left in the buffer?
hi all... very very sorry for late answer... in somehow issue disappeared. working well.
thanks a lot.
thanks a lot.
