Version 1.24.0 "whats new"
VK7XX
Post by VK7XX »
I have installed the subject version and once again 99% of the positioning of windows that I had set previously have been reset to their defaults. So far, the only window that stayed where I had it previously set to is the detached 'Previous QSO' window. This is sooooo annoying because I run Log4om on the right hand monitor of a 2 monitor setup and everything gets put back on the left hand monitor........ and even more so annoying since I have mentioned it on numerous occasions after the last 3 or 4 upgrades.
I rant, sorry.... as per the subject, I cannot find the list of changes from 1.23 to 1.24 so obviously I am looking in the wrong place. Would someone please point me to where this info is located. thanks all
John
VK7XX
Re: Version 1.24.0 "whats new"
Help/About/Release notes
VK7XX
Post by VK7XX »
G4POP wrote:Help/About/Release notes
Thank lots Terry. I think I am loosing it... I should have remembered that.
15.5 hours to Christmas here.. 73 and have a great day
John
This issue is due from the "recompilation" of Log4Om and subsequent obfuscation/optimization.
I'll try to "fix" that in the next release, but effects could be seen only in 1.26...
The issue is related to the function that stores Windows positions with form internal names, that are rewritten on every recompilation...
VK7XX
Post by VK7XX »
IW3HMH wrote:This issue is due from the "recompilation" of Log4Om and subsequent obfuscation/optimization.
Thank you for looking at this problem Lele.
regards
John
VK7XX
G4DWV
Post by G4DWV »
There is a utility that can fix that. It's shareware so give it a try. It is called WindowManager. I use it all the time on all my Win 7 installs.
Happy New Year.
