Setting custom station color in Cluster window
yt9tp
Post by yt9tp »
I wanted to set filter to mark 90IARU stations using different colur to make them easier to spot.
I opened custom filters for Cluster and set
Description: IARU
Colour background: yellow
Expression: (IARU)
After I test using for example VK90IARU call it shows OK.
I saved that and checked new filter to be active.
Nothing happens in cluster window. IARU stations are not colored.
Tried to restart application, did not help.
What am I doing wrong?
Re: Setting custom station color in Cluster window
This will only work if the call is displayed in the 'Notes' field not the call sign field
yt9tp
Post by yt9tp »
That axplains why it does not work.
Well, then this might become feature request :)
