I've upgraded to V 1.24
All was perfect under V 1.23
"Export" works fine...
Now I can't export Adi or CSV files
Message error is:
"Error exporting Adif log
Specified cast is not valid"
I'm just testing this software for some of my friends(4) who are now using Log4om.
If you need it, I can send you my "Log4om logfile" who's written in Roaming directory
73's Philippe F4BKT
V1.24 Problem II
Re: V1.24 Problem II
Yes please. iw3hmh (at) log4om.com
Please send me your DATABASE (sqlite file) in ZIP format
There is probably a bad value somewhere in your DB. I'll check
Ok Daniele
Thank's for quick answer and your great job.
I will see that tomorow morning or at the end of this day,
I've QRM pro..Hi
73's Phil
I've QRM pro..Hi
73's Phil
Hello Daniele
I've deleted all my "test" database and created a new one.
I'm now running with V1.24 and "export" works fine.
I will try now to set my own page with the new "Webpage" settings
Thank's for all and Congrats for your job.
73's Philippe
F4BKT
73's Philippe
F4BKT
