K1N, Navassa Isl
ct1hix
K1N, Navassa Isl
Post by ct1hix »
How do I register callsign K1N, Navassa Island?
TNX
73 CT1HIX Gomes
Re: K1N, Navassa Isl
Sorry, i'm missing what you need...
typing K1N should work, but you must set manual QSO date to fit the real date you made the QSO, otherwise our Special Callsign Database will not work with it.
In QSO INFO set MANUAL TIME flag and set the real QSO date, then type the callsign.
ct1hix
Post by ct1hix »
Sorry
In Portuguese it was easier... :D
I am work K1N in the 14/02/2015.
When I check "Statistics and Awords", does not appear as "W" (worked), because Log4om not identify the callsign used in the DX expedition.
K7PT
Post by K7PT »
You probably did not have the up-to-date SCL file is the reason K1N did not resolve to Navassa Is.
ct1hix
Post by ct1hix »
That's it!
When I input the QSO had not updated SCL.
I made updates and change the QSO data in "QSO Manager" etc etc etc
Thank you very much, and HNY!
73 Gomes CT1HIX
