Freq will not display
w8otr
Post by w8otr »
when I am using the programmed channels in my Kenwood ts590 using Omnirig Log4OM does not see freq. But HDSDR using the same Omnirig does see the freq of rig ......this has been a problem in all versions
Thanks Greg W8OTR
VK7XX
Re: Freq will not display
Post by VK7XX »
w8otr wrote:when I am using the programmed channels in my Kenwood ts590 using Omnirig Log4OM does not see freq. But HDSDR using the same Omnirig does see the freq of rig ......this has been a problem in all versions
Thanks Greg W8OTR
Greg, does the "CAT Status indicator at the bottom left side of the main Log4OM screen show as green ?? if not you have a setup problem somewhere. I am not familiar with the TS590 but for my Icom, in the 'Settings / Options' menu, on the tab 'Cat & Cluster' I have ticked in the box's for 'Omnirig' then 'Open CAT on program start' , CAT will set MODE when following spot' , CAT will switch to Digital...... maybe some of this will help. Happy New Year
John
VK7XX
w8otr
Post by w8otr »
stays green
