Logic 9 data export to log4OM
4x6uv
Post by 4x6uv »
After many years using different versions of Logic, I decided to move to log4OM and I wonder if I can import my QSO data from Logic?
Thanks for your attention.
73 Eli
CT1BXX
Re: Logic 9 data export to log4OM
Post by CT1BXX »
Hi Eli,
Welcome to Log4Om. I am sure you will love this software and also the develop team. :D
I have used Logic 8 and 9 I export to ADIF and then import to log4om from Adif file, no problems, it works fine. I did very litle corrections and it works just fine.
Best regards
73 Manuel Fernando CT1BXX
4x6uv
Post by 4x6uv »
Thank you for your reply CT1BXX.
I didn't think about ADIF, so simple...
You know, after using a certain application so many years, it's not easy sometimes, to switch to another one and get used to it... :?
Best regards.
VK7XX
Post by VK7XX »
Eli wrote:Thank you for your reply CT1BXX.
Best regards.
Hello Eli. Welcome to Log4om.
I would like to suggest that you change your user name to be you ham call sign, that way, we will all know who we are communicating with. It will make it a lot easier for keeping track of future posts as well.
regards
John
VK7XX
