Cluster questions
VA3KA
Cluster questions
Post by VA3KA »
I have been having difficulties keeping connected to the DX clusters (I have tried various clusters and all the same). After some random period of time (from minutes to hours) I get disconnected.
I do not think this is a Log4OM issue as I have tried from other computers (running a TELNET session) and get the same results. I think there may be an issue on my local network/router/internet provider (I have high speed access).
But I have a few questions on the cluster configuration (under Utilities).
1. I have the cluster heartbeat enabled. How does this work? I assume it sends a blank command after a certain period of time to keep the cluster alive? If so is there a way to change this time period?
2. What does the Timeout selection control do?
3. I have the Run logon script enabled. But in many cases, my call sign appears to be sent before the cluster is ready for it and I get an "invalid call sign" error from the cluster. Is there a way to program a delay in the logon script to allow the cluster to be ready to receive the logon callsign?
Thanks and 73,
Ken VA3KA
Re: Cluster questions
VA3KA wrote: 1. I have the cluster heartbeat enabled. How does this work? I assume it sends a blank command after a certain period of time to keep the cluster alive? If so is there a way to change this time period?
You are correct but the keep alive interval cannot be changed
If no response is received from the cluster in the selected interval a pop up window indicated 'Not connected'
Use
<DELAY>
<DELAY>
In the script before call sign, from memory each occurrence is equal to 1 second
ac5aa
Post by ac5aa »
I've been having the same "invalid callsign" response from the cluster because the callsign and "sh/dx" is all sent too quickly. Thanks for describing the "fix," Terry.
73, Duane
73, Duane AC5AA
