PSTRotator integrstion
W2JAZ
Post by W2JAZ »
I've had numerous problems since installing new version of SmartSDR. I eventually reinstalled Log4OM and got it working again. But I cannot get log4OM to control PstRotstor and ERC rotator control interface. Manual operation works fine via PSTRotator but no automated control via Log4OM which had worked perfectly before win10 and SmartSDR upgrades. Any any ideas?
Rick,W2JAZ
NN7D
Re: PSTRotator integrstion
Post by NN7D »
Hi Rick,
Make sure both Log4OM and PSTRotor are started to run as Administrator. Then make sure Communicator is running, and make sure Communicator and PSTRotor are configured as page 169-171 of the Users Manual describes.
Windows 10 does everything possible to prevent software from communicating with each other, so you may also have to lower your security settings if the above does not work.
Let us know if the above does not get it working.
Doug - W7DRM
